SVTJON87
dose this really work? or is it just snake oil
http://spmotorsports.com/ATCelectricalignition_groundingsys.html
20cougar00 would your lights blink or get demmer when you where driving and let off of the gas?Because mine does this now and I was hoping it was something like a grounding issue and not a bad alternator.
dose it only happen when you start the car and then turn on your lights?Was there an update for post-install?? I had the problem in my first '99 Contour and ended up replacing battery cables, alternator, and fiddling with some wiring to get the symptom to minimize. If/when it happens again in my two '99 Contiques I have now, I'd like to get it fixed properly.
