jakemeister
New CEG'er
Hi:
I have a clunking noise coming from the front left of my 98 Contour at low speeds, after reading through the forums, I did some checking, and found it to be a loose front strut or top mount?
I can turn the top mount around, as it seems to be loose, but the nut is really tight?
Is there a way to tighten this up, as the struts seem to be working properly, or is the strut or top mount toast?
Any help or suggestions would be appreciated?
Thank you, Jake.
Thank you, Jake.
