2000SilverSVT
Last night I was changing out the Head Unit in the car and after I completed the task that Climate control will no longer change the vent output.  It is currently stuck on defrost vents.  It will not change to dash or floor.  The AC will still kick on and so will defrost.  Fan speed is working as well as temprature control.
I have noticed two strange things. A coil spring appeared on the floor where none existed before. I also found a large lightbulb on the floor as well.
Anyone have any ideas on why the vents will no longer change and where the spring and light bulb could have come from?
I also had the glove box pulled down to access the speaker wire connection by the internal amp.
