F ford4life Veteran CEG'er Joined May 3, 2008 Messages 714 Location Livonia MI Sep 17, 2008 #1 how do i remove the piece around the cluster? it has 3 vents in it. i removed the 2 screws i see is there more?
C CSVT1214 Addicted CEG'er Joined Nov 1, 2003 Messages 6,752 Location Plainville, CT Sep 17, 2008 #2 Most interesting spelling of "bezel" ev3r! 5 screws total. 1 behind the defrost button, 2 in the center, 2 behind the clock/Contour plate.
T Tex Hard-core CEG'er Joined Jan 8, 2008 Messages 3,168 Location Fort Worth, TX Sep 17, 2008 #3 There is a how-to, with pictures even, somewhere on here if you'll search for it. It may be on the main site page, not in the forums.
F ford4life Veteran CEG'er Joined May 3, 2008 Messages 714 Location Livonia MI Sep 17, 2008 #4 Thanks. i was not sure what it was called.
T TourEnvy Hard-core CEG'er Joined Oct 23, 2006 Messages 2,725 Location Las Vegas , NV Sep 17, 2008 #5 To remove the brezzel from the whole, I would start at there very top and work your way down. Good luck!
F ford4life Veteran CEG'er Joined May 3, 2008 Messages 714 Location Livonia MI Sep 17, 2008 #6 any way i got the bezel off thanks for the help. Now there is a clear tube. looks like its connected to a vac line. running up the pillar. with wires for a gauge hook up. i think. what gauge would the be?
F ford4life Veteran CEG'er Joined May 3, 2008 Messages 714 Location Livonia MI Sep 17, 2008 #7 Some photo's Attachments PICT0077.jpg 90.8 KB · Views: 0 PICT0078.jpg 90.9 KB · Views: 0 PICT0079.jpg 81.8 KB · Views: 0
T Tex Hard-core CEG'er Joined Jan 8, 2008 Messages 3,168 Location Fort Worth, TX Sep 17, 2008 #8 Looks like a VAC gauge based on what it looks like it is hooked up to in the last pic.
F ford4life Veteran CEG'er Joined May 3, 2008 Messages 714 Location Livonia MI Sep 17, 2008 #9 Yeah it is
