Wiring problem!!!!
bigtime41
Well some *******s broke into my car and messed up my wiring. I fixed all my purge and nitrous wiring and the underbody but here's the problem. I have this green wire that I can't figure out where the hell it goes.....is it a relay??? Because when I turn on my turn signals all the lights in the interior blink along with it....the hvacs, speedometer etc all blink in conjunction with the turn signals. Fuse, relay, anyone?? please help
... I have this green wire that I can't figure out where the hell it goes.....is it a relay??? Because when I turn on my turn signals all the lights in the interior blink along with it....the hvacs, speedometer etc all blink in conjunction with the turn signals. Fuse, relay, anyone?? please help
Where exactly is this green wire? You may want to post a picture.
I'm confused. Is the green wire loose like they cut both ends and left a chunk sitting in your car? Or is one end cut and the other goes somewhere. If the latter, please let us know where the one end goes so we can help. I'll venture a guess that there are lots of green wires in your car...
well then forget about the green wire.....what would make the interior lights blink with the turn signals??
A short in your wiring. That green wire may have something to do with it. You need a tester to find the end of it in the fuse box because if it is a solid green it is most likely power to something. I was just looking a some pinouts and I think there is a solid green to the multifunction switch. (turn signals) But I'm just speculating.
my 2 cents
Thanks Aussie....that sounds like a good theory....I'm just at work 60 hours a week during this damn holiday extravaganza and haven't found time to even look into it further.
Get me a pic or video of this wiring and where it is located and what was all cut up(radio harnes, ignition harness, etc).... Also did you have an aftermarket security system installed at all? I should be able to help you more if you can get that information.
