95 Contour Safety Recalls ???
richie65
New CEG'er
While searching the internet I found two different websites that appear to identify safety recalls. On the site "AboutAutomobile.com", one of the identified safety recalls, #98V233000, created September 25, 1998, was applicable to the replacement of the console automatic transmission shift position indicator, ie, PRNDSL indictor. Seems this sliding indicator was made of a flimsy and poor quality plastic material that deterioriates over time, and totally disintegrates into nothing. This leaves the driver without any indication of what the transmission drive gear is, and can be a hazard while driving. This was identified in the above safety recall in 1998, and indicated that the Ford dealer would replace the shift indicator under the safety recall.
When the shift indicator on my 95 contour failed as described, I called the local dealership. They claimed that there was no such safety recall that pertained to my Contour VIN. I then contacted the FORD Motor Co about this, and they told me the very same thing - no such recall applies to my Contour VIN. This is very puzzling because the safety recall identifies a failure of material used in manufacture, or a manufacture's defect, that is of a generic nature applicable to all 95 contour's with the floor console automatic transmission shift lever. The failure is not of a peculiar nature such that it would only apply to some 95 contours and not others. However the Ford people told me that the only way they can check for Safety recalls is by using the vehicle's VIN number, and my 95 Contour's VIN did not show any such Safety Recall, and they further identified only two websites, genuineservice.com and customersaskford.com, as the only sites that have the valid Safety Recalls for Ford vehicles. When I checked those sites, the above Safety Recall is not shown for my Contour's VIN.
Has anyone experienced the came problem with safety recalls? How can the one site, aboutautomobile.com, and others provide a list of safety recalls that confilcts with safety recalls that the manufacturer claims are valid? Does anyone know what the reasons for such a disagreement would be? Why would AboutAutomobile.com provide such a misleading list of safety recalls?
no I haven't but I do know that recalls often only apply to certain identified vehicles. maybe the one site didn't have that information of just presents it in a way that it didn't bother referencing that information.
RE: 95 Contour Safety Recalls ???
BrApple you replied:
Yes, the recalls can apply only to certain vehicles and not others. And the website AboutAutomobile.com safety recalls had sufficient clarifying information to identify which cars the recal applied to, ie certain engine sizes, etc. Here is what the website identified for this safety recall for the 95 Contour. It identifies applicability to passenger vehicles that have automatic transmission floor shift. This is a generic safety recall without any other restrictions. However, FORD representatives deny the applicability to my 95 Contour VIN even though my car meets the requirements.
Where else would aboutautomobile.com obtain the specific information about this safety recall other than thru the Ford Motor Company, the manufacturer of the 95 Contour? If the information originally came thru the Ford Motor Company, why would Ford be denying its applicability now?
From the aboutautomobile.com website.
1995 FORD CONTOUR 98V233000 Safety Recall
Year: 1995
Make: FORD
Model: CONTOUR
Recall Number: 98V233000
Owner Notification Date: November 20, 1998
Recall Creation Date: September 25, 1998
Component Description: Power Train:Automatic Transmission:Lever And Linkage:Floor Shift
Manufacturer Involved in This Recall: Ford Motor Company
Report Received Date: September 18, 1998
Defect Description:
Vehicle description: passenger vehicles. The floor shift automatic transmission control can be damaged if subjected to certain interior cleaning products. The gear position indicator can deteriorate and not correctly indicate the actual gear position.
Defect Consequence:
This condition can result in incorrect gear selection.
Corrective Action:
Dealers will replace the automatic transmission floor shift control.
There are two "sets" of 1995 Contours, the first one has a cable driven speedometer and the second has an electronically driven speedometer like all other Contours... Maybe this only applies to the cable driven "set" or vise-versa? I do not know the dates or what else varys between the two, but to determine which one your's is: on the cable driven speedos the 1/10 miles number in the tripometer is orange on black and then on the electronically driven speedos the number is black on white...
Plus anyways, you should be more worried about the wiring harness recall :shrug:
^^ You are correct!
Cable Driven:
Electronic:
thank you learned somthing ,if 100 % true? I'll have too check mine
I want a new harness but with 193000 miles guess I'am S O L:mad:
Thanks for your input, BoSoxBruin. I believe mine is the cable driven speedo. Had to replace the cable awhile ago. It ate itself up and broke. Don't know why this item was never a safety recall, since there are a few others who've posted on the forum and had the same thing happen.
You could be right in saying that this might be why my car doesn't show the recall for the automatic transmission floor shift indicator. But the recall only qualifies the requirement by stating that it applies to passenger cars. And I can see why it's a safety recall, because this afternoon I parked my car. When I returned, I inserted my ignition key, and then noticed that the transmission had been left in reverse. It's a good thing that I had the parking brake on.
I probably will try to take a picture of the indicator problem. Seems to me that all of the 95 Contours with an automatic floor shift should have the very same configuration and appearance, and if they haven't had the same disintegration of the shift indicator, then they will.
Tried to find out where I could find replacement indicator for my 95 Contour, but haven't been successful yet. Have any idea where I can find a source for the transmission shift indicator?
Thanks for the link, BoSoxBruin. I went to the NHSTA webpage a few days back and couldn't find the recall listed when I searched for my car. I spoke to the NHTSA representatives, and they couldn't find any such recall for my car. Since the recall does appear on the NHTSA webpage search results, I will contact NHTSA tomorrow to see if they can tell me which 95 contours it applies to, and what excludes my p5 contour. Seems like they would be able to do that, wouldn't you think? I just don't undertand why my car is not included, since it's a passenger car, and should be included.
