Savior
OK, so my ABS (Anti-Lock Braking System) has never worked. Eventually I just pulled the light bulb out from behind the dash and forgot about it. Recently, I noticed that my fog lights don't come on either. No idea how long this has been going on; they may never have worked.
So I got to hunting for fuses and relays to see if I could get my fog lights to work. Lo and behold, upon examining my Power Distribution Box under the hood next to the diagrams in my Owner's Manual, I come to discover that some fuses and a relay could be missing. Relay R1 (labeled "Daytime Running Lamps") is missing. I don't know what Daytime Running lamps are... Foglights? Or the yellow parking lights..?
Fuses 6 and 8 are gone as well. These are labeled "Foglamp" and "ABS System" in the manual. Strangely though, their red bases (the actual sockets that you plug the fuses directly into) are missing as well, leaving only black holes in their absence. See images below...
So... Should I have the red bases in those fuse sockets? Where could I get them? And should I have a relay in that R1 relay socket? What rating/type of relay should be there? Can anyone peek under their hood and tell me if the last owner of this car might have broken or lost some of these things?
[EDIT] - And one more thing, I just noticed... Fuse 7, according to the chart, is "Not Used". But there is a yellow 20-amp fuse in there... What the heck..? Is that normal? Did someone pull a fuse and accidentally yank a red "dock" out along with it, and then plug it back into a dead, unused hole or something..? 0.o
[EDIT] - And another thing! Fuse 9, that big blue one (Far right side, third one down), is also listed as "Unused" in the manual's chart, but there is definitely a fuse in there... WTF is wrong with my car's fuse/relay setup? I'm so confused now. I thought I might have the wrong Owner's Manual, but it say "1998 Model Year" and SVT on the front. Can anyone clear this up?
