Cam position sensor err
sl33k3r
Be Gentle I'm New Here
98 Contour, 2.0 Zetec
I have an AutoXray 6000 and it gives Cam Position Err. Would this cause flooding? The engine does make an attempt to start, but to no avail. Only a few fires and leaves the plugs soaked with fuel.
Vehicle Data
Readiness Monitors Complete Yes
Fuel System 1 Open Loop
Fuel System 2 Not Supported
Load Value 0.0 %
Coolant Temp 41 °F
Short Term Fuel Trim1 85.1 %
Long Term Fuel Trim1 0.0 %
Engine RPM 0 RPM
Vehicle Speed 0 MPH
Ignition Timing Adv 0.0 °
Intake Air Temp 39 °F
Air Flow Rate 0.00 lb/min
Throttle Position 17 %
Oxygen Sensor 1 Bank1 0.000 V
Short Term Fuel Trim1 85 %
Oxygen Sensor 2 Bank1 0.000 V
Short Term Trim2 Not Supported
OBD II Require OBD II (CARB)
A/C Not Requested
Brake Depressed No
Four Wheel Low Not Requested
Park Neutral Detected
Trans Control Switch Off
Power Steering Load No
A/C Pressure Sensor Low
Field Octane Requested
Canister Purge Not Requested
Low Speed Fan Off
High Speed Fan Off
Malfunction Light Off
OBDII Trip Completed No
A/C Clutch Not Engaged
Trans Control Light Off
Secondary Air Pump Off
Shift Solenoid A Off
Shift Solenoid B On
Shift Solenoid C Off
Coast Clutch Solenoid Off
Baro Pressure 29.35 "hg
IAC Duty Cycle 0 %
Throttle Position 0.87 V
Long Term Trim Bank1 0 %
Long Term Trim Bank2 0 %
Short Term Trim Bank1 86 %
Short Term Trim Bank2 86 %
Engine Load 0 %
Engine Speed 0 RPM
Spark Advance 0 °
O2 Sensor1 Bank1 2 mV
O2 Sensor1 Bank2 0 mV
O2 Sensor2 Bank1 0 mV
O2 Sensor2 Bank2 0 mV
Turbine Shaft 0 RPM
Line Pressure Ctrl 17 psi
Power Take Off Not Engaged
Power Steering Sensor 0.46 V
O2 Sensor1 Bank1 Heater Off
O2 Sensor1 Bank2 Heater Off
O2 Sensor2 Bank1 Heater Off
O2 Sensor2 Bank2 Heater Off
Engine Torque 0 ft-lbs
Rear O2 Trim Bank1 0.0 %
Rear O2 Trim Bank2 0.0 %
Cam Position Err -15 °
Cam Duty Cycle 0 %
Num Completed OBD IITrips 0
Num Comp OBDII DriveCycles 0
Continuous DTC Counter 0
Intake Air Temp 40 °F
Throttle Pos Mode Closed
Commanded Drive Gear 1
TCC Ratio 3.99
OK, this is what I found out today
Thanks for swift reply.
Forgot to note. New coolant sensor, spark plugs and wires. Temperature guage in dash is in middle all of the time ... cold or hot.
Today I can:
unplug the coolant sensor (on top of the thermostat housing, btw - coolant sensor works properly) hold accelerator pedal to floor and car will start. Rough idle, but it will start. Plug coolant sensor back in and idle smooths right out.
OR
unplug coolant sensor, short across wiring harness to make computer believe car is hot and car will start. Again ... rough, but it starts. Remove the jumper and plug the sensor back in and engine smooths right out.
What could cause this ... not starting with the coolant sensor plugged in?
I almost forgot ... when running, camshaft sensor err is 0 Degrees.
Also, it looks as though the wiring harness is in good condition.
The data posted is in Open loop (engine not warmed up) and not very useful other than your Throttle Position Sensor is working and your Camshaft Position sensor is not working. Check/change CMP and wiring and see if it improves.
Edit. Assuming that the car was idling and the steering wheel was close to straight, the Power steering switch is working too.
OK, will check CMP wiring again. Car is not here. Will post tomorrow. But here is data downloaded today.
I'm not familiar with short and long term fuel trim. Could I be enlightened, please?
OBDII Generic
Year = 1998
VIN =
Trouble Codes
Pending Codes
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
Readiness Test Results
MIL Status Off
Misfire Monitor Completed
Fuel System Monitor Completed
Comp. Component Completed
Catalyst Monitor Not Completed
Heated Catalyst Not Supported
Evaporative System Not Completed
2nd Air System Not Supported
A/C Refrigerant Not Supported
O2 Sensor Not Completed
O2 Sensor Heater Not Completed
EGR System Not Supported
Vehicle Data
Readiness Monitors Complete No
Fuel System 1 Closed Loop
Load Value 50.1 %
Coolant Temp 188 °F
Short Term Fuel Trim1 -20.4 %
Engine RPM 802 RPM
Vehicle Speed 0 MPH
Ignition Timing Adv 27.5 °
Intake Air Temp 69 °F
Air Flow Rate 0.30 lb/min
Oxygen Sensor 1 Bank1 0.905 V
Short Term Fuel Trim1 -21 %
Oxygen Sensor 2 Bank1 0.920 V
A/C Not Requested
Brake Depressed No
Low Speed Fan Off
High Speed Fan Off
Shift Solenoid B On
Baro Pressure 27.72 "hg
IAC Duty Cycle 43 %
Short Term Trim Bank1 -20 %
Short Term Trim Bank2 33 %
Engine Load 17 %
Engine Speed 802 RPM
Spark Advance 27 °
O2 Sensor1 Bank1 905 mV
O2 Sensor1 Bank2 920 mV
Turbine Shaft 769 RPM
Line Pressure Ctrl 0 psi
Power Steering Sensor 0.70 V
O2 Sensor1 Bank1 Heater On
O2 Sensor1 Bank2 Heater On
O2 Sensor2 Bank1 Heater On
O2 Sensor2 Bank2 Heater On
Engine Torque 12 ft-lbs
Cam Position Err -1 °
Cam Duty Cycle 0 %
Continuous DTC Counter 3
Intake Air Temp 70 °F
TCC Ratio 0.96
Freeze Frame Data
Capture Data
Thanksgiving day
Good reading material for fuel trims here. Cliff notes- SHRTF for temporary engine conditions. Engine switches parameters in LONGFT if SHRTFT has issues which cannot be corrected by PCM in the temporary period.
http://www.v8sho.com/SHO/TSB0197HO2SServiceTips.htm
I suspect your "wacky" SHRTFT and ECT numbers are due to you unplugging the ECT. I suggest you go the CMP route first and see if it helps. If that doesn't, I would look at cleaning the IAC valve. Post again after you try those suggestions.
Edit. Zetec IAC valve cleaning
Zetec IAC location.
For the Zetec I-4, you need to access the IAC from the bottom of the car.
IAC cleaning
from Ray's UIM/LIM how to in Duratec Maintenance how to.
"Replacing the IAC gasket:
(From IAC faq)
Over time, the IAC (Idle Air Control) valve becomes sticky due to buildup from the EGR and PCV systems. It can stick partially open such that idle quality is adversely affected, and engine RPM's will not drop below 1500. For a while, blipping the throttle will restore normal idle, but this only works for so long.
The fix is to remove the IAC valve by unbolting the two 8mm bolts that hold it on and disconnected the wiring plug. If you are careful enough, replacement of the gasket will not be necessary. The gasket costs less than US $1.00, so it is no tragedy if you destroy it. Once the valve is off, spray it out with some carb/intake cleaner and make sure any gunky residue is gone. Reattach, and you are done. It is a lot cheaper than a new IAC, which runs around US $70. Note: Ford claims the IAC cannot be cleaned, but this is not true in my experience." Ray.
Location of the IAC for the Zetec.
"It's on the back side of the intake plenum under the throttle body area." DESIGN.
I looked at the Haynes manual and the Zetec IAC valve is located next to the starter. Below are the steps from the 1996 Ford CD to remove it .
Idle Air Control (IAC) Valve
Removal
1. Disconnect battery ground cable
2. Remove the air cleaner outlet tube and resonator assembly.
3. Disconnect the main chassis vacuum line.
4. Disconnect the ignition coil and radio interference capacitor wiring.
5. Remove the fuel line bracket retaining bolt.
6. On 2.0L engine equipped vehicles, raise vehicle on hoist.
7.
7. Disconnect the engine control sensor wiring or fuel charging wiring (depending upon application) from the idle air control valve (IAC valve) at the idle air control valve connector.
8. On 2.5L engine equipped vehicles, remove retainer for engine control sensor wiring from the upper retaining stud bolt.
9. Remove the two idle air control valve retaining bolts or stud bolt (depending upon application).
10. Remove the idle air control valve and idle air control valve gasket.
Installation
1. Note: If scraping is necessary, be careful not to damage idle air control valve or intake manifold idle air control valve gasket surfaces or drop material into intake manifold.
Clean idle air control valve gasket mating surfaces.
2. To install idle air control valve, reverse Removal procedure. Tighten the fuel line bracket bolt to 8-12 N-m (71-106 lb-in).
3. On 2.5L engine equipped vehicles, tighten the retaining bolt and stud bolt to 8-12
4. On 2.0L engine equipped vehicles, tighten the idle air control valve retaining bolts to 8-11 N-m (71-97 lb-in).
