98 Contour, 2.0 Zetec
I have an AutoXray 6000 and it gives Cam Position Err. Would this cause flooding? The engine does make an attempt to start, but to no avail. Only a few fires and leaves the plugs soaked with fuel.
Vehicle Data
Readiness Monitors Complete Yes
Fuel System 1 Open Loop
Fuel System 2 Not Supported
Load Value 0.0 %
Coolant Temp 41 °F
Short Term Fuel Trim1 85.1 %
Long Term Fuel Trim1 0.0 %
Engine RPM 0 RPM
Vehicle Speed 0 MPH
Ignition Timing Adv 0.0 °
Intake Air Temp 39 °F
Air Flow Rate 0.00 lb/min
Throttle Position 17 %
Oxygen Sensor 1 Bank1 0.000 V
Short Term Fuel Trim1 85 %
Oxygen Sensor 2 Bank1 0.000 V
Short Term Trim2 Not Supported
OBD II Require OBD II (CARB)
A/C Not Requested
Brake Depressed No
Four Wheel Low Not Requested
Park Neutral Detected
Trans Control Switch Off
Power Steering Load No
A/C Pressure Sensor Low
Field Octane Requested
Canister Purge Not Requested
Low Speed Fan Off
High Speed Fan Off
Malfunction Light Off
OBDII Trip Completed No
A/C Clutch Not Engaged
Trans Control Light Off
Secondary Air Pump Off
Shift Solenoid A Off
Shift Solenoid B On
Shift Solenoid C Off
Coast Clutch Solenoid Off
Baro Pressure 29.35 "hg
IAC Duty Cycle 0 %
Throttle Position 0.87 V
Long Term Trim Bank1 0 %
Long Term Trim Bank2 0 %
Short Term Trim Bank1 86 %
Short Term Trim Bank2 86 %
Engine Load 0 %
Engine Speed 0 RPM
Spark Advance 0 °
O2 Sensor1 Bank1 2 mV
O2 Sensor1 Bank2 0 mV
O2 Sensor2 Bank1 0 mV
O2 Sensor2 Bank2 0 mV
Turbine Shaft 0 RPM
Line Pressure Ctrl 17 psi
Power Take Off Not Engaged
Power Steering Sensor 0.46 V
O2 Sensor1 Bank1 Heater Off
O2 Sensor1 Bank2 Heater Off
O2 Sensor2 Bank1 Heater Off
O2 Sensor2 Bank2 Heater Off
Engine Torque 0 ft-lbs
Rear O2 Trim Bank1 0.0 %
Rear O2 Trim Bank2 0.0 %
Cam Position Err -15 °
Cam Duty Cycle 0 %
Num Completed OBD IITrips 0
Num Comp OBDII DriveCycles 0
Continuous DTC Counter 0
Intake Air Temp 40 °F
Throttle Pos Mode Closed
Commanded Drive Gear 1
TCC Ratio 3.99
Vehicle Data
Load Value 0.0 %
Coolant Temp 41 °F
Engine RPM 0 RPM
Vehicle Speed 0 MPH
A/C Not Requested
Brake Depressed No
Low Speed Fan Off
High Speed Fan Off
Shift Solenoid B On
IAC Duty Cycle 0 %
Engine Load 0 %
Engine Speed 0 RPM
Spark Advance 0 °
Turbine Shaft 0 RPM
Cam Duty Cycle 0 %
TCC Ratio 3.99
	 .  Check if connector is loose, or wiring is broken.  If it checks out fine, change the camshaft position sensor.
