getsum111
Yes I am a Pirate, 200 years too late.
OK guys, still working onn figuring out my misfire/lean problem, and since I know what is causing it, it wanted to starrt a new thread. I was getting code 1131, replaced the O2 sensor, then got codes 1171, 0306, and then 0300. Found that the hose from the PCV valve that goes along the firewall had touched the EGR and melted a hole in it. It looks like a corrugated/convoluted tube, like you woiuld use to hide wiring. I think it is called the PCV to EVAP Emissions hose, can anyone confirm this? I tried to seal it with tape, but it still seems to be leaking. This hose has two light grey clips/tabs that somehow loosen the connection at the end. Is this a dealer only item? And can I cut out the section that is leaking, slide a connector between the two pieces, and then use hose clamps to put it back together? Thank you.
