bensenvill
ok so after the car sitting pulled apart for a long time, everythings back together and I'm trying to start the darn thing.
The starter is cranking the engine but its just not turning over. I have a bit of whiff of gas so I think its getting fuel but I have no idea if its getting spark or not and am not sure how to go about proving that. I'm using a jump starter pack so I should be pushing enough CCA's to turn it over.
things that might be pertanent:
the alarm system has been cut out [was proved to work removed before it was cut out].
The IMRC wiring was extended, I trust my soldering work.
An SVT TB was swapped in [well actually its a 3L TB], the TPS sensor was swapped from my stock TB.
All wiring in the car was pulled and later reinstalled, I like to think I didn't miss anything and have double checked most of it.
any ideas... I'm so close.
