CSVT1214
Addicted CEG'er
My brother's car has been popping up a CEL every once in a while and then goes out usually after letting off the throttle.
I scanned the codes tonight and came up with the following:
117 - ECT sensor is/was low or grounded - ECT
218 - IDM signal open or high or left coil pack failure - Ignition Systems
133 (?) Unknown code. Confirmed it at least 5 times to make sure that I wrote down the code correctly
646 - Transmission 2nd gear failure - Transmissions
Now with the tranny code, I'm not sure if it was a one time code or if the tranny is on its way out. The car has a slow leak from one of the ATX cooling lines and it was leaking faster than I thought and ran too low on fluid. I added fluid and drove it around tonight and it felt fine. I won't know till it sees some more time on the road if it's ok or not.
1995 Mystique Zetec ATX
