So I had a little engine trouble along the way last week. And over the weekend/beginning of the week the car was torn apart. I made an interesting little discovery...
Below the lower intake manifold there is a cap or what I deemed a "bonnet" that the pvc line connects too. This bonnet bolts onto the block.
Now i've had a stain on the left side of the block (belt drive side) since I got the car at 67K. It was always a slow leak, never got worse, never changed. It was just a slow slow seep out from somewhere.
So when rebuilding my the upper, lower, plugs, valve covers, I found this bonnet and found out something that just about put me over the edge! The cap WAS NOT TIGHTNED DOWN! The bolts down, but were removalable by hand! There is a gasket underneath and it was completely soaked through with oil! :idea:
Also in the immediate area the top of the block was stained just like the side of the block with oil. So guess where the stain on the side of the block comes from!
It was a PITA to fix because I removed the gasket and the bonnet does not come out from between the block without taking off the radiator hose. It was stuck to the block I couldn't pull the radiator hose off. So I managed to take the gasket off and reinstall by feeling in the dark underneath.
Now I have seen this on ALOT of contours (stain on side of block). So I'm assuming someone along the assembly line was not doing there job. :nonono:
My build date for the motor is late december 97. Not sure if that would have anything to do with it, but this issue may be build date related.
This is one of those things that could effect idle as well, so all along those lines of mystery idle issues, heres another one for the list!
Also would cause a slow loss of oil to an unknow location depending on how much is blowing through!
I tried to get pictures, but my digital camera has come to see the ends of its days. Maybe someone can posts pictures from a upper and lower rebuild, or wait until I try to fix my camera!
