morbid
I've been running this setup for almost 2 years... I'm just finally getting around to posting pics though. Powersteering cooler on the left, engine oil cooler on the right. In a rush to make the parts work, I notched the frame in two places for the engine oil cooler fittings. I regret doing that now as I'm getting some short fittings that should clear the frame. I'm also about to replace the rubber hoses and 8AN fittings with steel braided and 10AN fittings.... and moving the filter to the passenger side. That will be much cleaner.... the hose mess has always bugged me. Also, one of the fittings on the thermostat is slightly leaking/bleeding on one of the hoses.
