sav0320
I was supposed to drive my dad's T-Red SVT across Michigan Thursday after his shifter repair - the result of a failure mode that apparently leaves a chunk of a bolt in the trans case. The repair shop said the chunk would be caught by the drainplug magnet. I had serious worries about driving 75-80 mph (OK, 143 mph
) in the car. (I also spent 6.5 years as a transmission engineer...) Sure enough, with my wife behind me in the Grand Caravan, I take the car up past the secondaries in first, and about halfway up through second, I hear this pop pop pop, BANG!
Getting off the throttle, engine braking in gear, I kept hearing a pop pop pop at irregular beats. Limped it back to my house. Tonight I rolled the car back and found the ATF bloodstains in the driveway. Confirmed a major tear/crack around the ring gear/trans case. I thought the bolt chunk got stuck between the ring and pinion. Thought wrong. Check out the pics.
What are our options? Ford does not reman manual transmission from what I understand, so are we stuck with some third party that buys the cores to do reman? Stuck with a new trans? Is there some super MTX-75 build-up shop? The G5M (Mazda) manual in my Fission blew up (extra dowel pin in the bellhousing) and that was a $3500 repair with parts and labor.
Thanks.
Thanks.
