97 contour cd4e trans?
xpdude
elgin
P1744 tcc stuck off came up for a transmission scan as resalt of it shifting out of overdrive on the highway. Drives fine for about 20-30 mins if iam lucky, then it messes up. Is this a easy fix? The cd4e trans shifts hard when this occors. Are there any sensors I can replace that may improve this issue? I have put another transmission range sensor on from a donor and this helped alittle. Have also added new fluid as well as slick 50 trans addictive. Burning the fluid and I need to fix this! Is that because of no O/D 5th tcc lockup? Are all the cd4e tranys the same? like the ford escape probe mazda ect?
