Aussie Ford
Rear Roll Restrictor repair & replacement – Aussie Ford 6/08
So I looked around and the only sources for a replacement I could find was Ford $75 + SH or a junk yard. Well Ford is real proud of them IMO and jy ones all seem to be as bad as mine, so having grabbed and extra one from the jy ($5) I proceeded to remake my own poly fill ($40).
1) Clean the part. Then do it again.....
2) Center the hole in the housing. Make a cardboard template to fit the bottom. It should fit around the inside of the housing, and around the center tight. I used a stiff cardboard that was shinny on one side. Fitting tight will help align the sleeve and keep it in the middle. There are two rubber nubs on the sleeve I decided to save them so I could orient the center.
3) Remove the rubber insert. I found that cutting it out with a razor knife worked well. I stretched it with a screwdriver and cut it. Only had to cut about 1/2 of one side out to be able to manipulate the rest out.
4) I left the rubber on the very ends and cut the rest away with a razor knife and pliers to stretch it.
5) Finished by cleaning it up with a wire brush in a drill. Then wiped it down again with some brake cleaner.
