How much more lift from increased rocker ratio
SicSE
Kennesaw, GA
This is hypothetical, let's not argue about specs, just someone chime in with the applicable calculations.
How much would valve lift increase by upping the rocker arm ratio from 1.8 to 2, given valve lift of 9.8mm & lobe lift of 4.8mm?
valve lift = lobe lift * rocker ratio. how hard is that? :shrug:
4.8*1.8=8.64 valve lift
4.8*2.0=9.6 valve lift
9.8/1.8=5.444 lobe lift
9.8/2.0=4.9 lobe lift
9.8/4.8=2.04 rocker ratio
