I just finished changing my oil and suspect I have a big problem. When I started undoing the sump plug, I put a little (and I mean not very much at all) pressure tightening it, and the bolt started turning with almost no resistance. There was a lot of fine metal in the oil that came out so I am hopeful that all the bits came out.
I put the bolt back in and it threaded in OK and tightened up firm (I didn't go too hard on it), and its not leaking oil, but I'm now concerned about starting the car. Does pressure build up in the sump?
Is the only way to fix this to replace the oil pan?
I am having some work done on the car this week in preparation for doing an open track run this weekend, so I could have something done then, but I just put 50 bucks worth of oil in it so I'd rather not.
So 2 questions:
1. Can I start the car and drive normally without blowing the plug out?
2. Do I need to replace the oil pan or have the thread repaired before I track the car this weekend?
Help please, I have a feeling this is going to be a big PITA.
So 2 questions:
