beyondloadedSE
Do you by chance have a number for MSDS?
It's on their homepage on their website. www.msdsinc.com :idea:
I know very little about turbo setups, but a guy I know has a business making turbo manifolds and for his flanges, I believe he just gets an exhaust manifold gasket and sends it to whoever makes his flanges and they use the gasket as a template to cut the flanges. Just figured I'd toss that idea in there too, if you can't get just flanges from MSDS.
You can indeed cut off the precats and weld tube to the stock manifolds. I had one done by a friend of mine. The metal those things are made of is a pain in the butt to cut, but it seemed to weld well.
You have to work on it a bit to transition from the manifold to tube but any competent metal fab/welder should be able to do it no problem.
And what i meant in my above post was to take a stock manifold and have it taken to someplace that could copy it.
They're not cast iron. They are some kind of steel I believe.
If I recall correctly i believe they are like a muti-part stamping welded together.
FWIW, let's not forget this is a FWD platform. Even though you want to spool up quicker, it's only going to hurt you in the long run. You might as well just throw up the engine in the trunk like the Noble/Rossion to make it RWD or just convert the car to RWD.
Good to know thanks. Does anyone have a set of 2.5L exhaust manifolds, that they are willing to sell?
why was this post ignored? the last thing this platform needs is instantaneous boost. why not cut out the middle man and just snap your axles, kick yourself in the balls, and then burn the money.
I have a used garret gt28r I would sell you. Not sure if Stazi has his of that same size anymore. That would be two very appropriately sized turbos for your project.
Both are dual ball bearing oil and liquid cooled.
Good lucky with your build, PM if interested.
I believe people run the gt28r's on the nissan 300zx 3.0L with 8.5 compression pistons. I want to say i read HP# in the 400-500 range.
But the size Im running they are TD05's, a little bigger than the 3000gt twins, if that helps.
Intercooler wise, Im having one custom made that will have two inlet ports, one for each turbo, and one outlet. Have not determined dia yet. Any recs?
	I just thought of this, but why are you not using the Noble manifolds?? :shrug:
I thought about that, but then realized that I cant because Im using 2.5L heads not 3.0L heads. I little more work then what I wanted. Im just going take a set of 2.5 manis and port match.
I have the heads done already and will post pics this weekend as well as pics of the car as well.
