Gauge choices....
Pole120
Addicted CEG'er
Waukesha, WI
I've got a 2-5/8" oil pressure gauge installed in my custom dash pod and i'm adding a pillar pod this winter. I'm thinking of adding:
Water temp
Oil Temp
Volts
Good choices? Suggestions?
~Josh
sound like good picks to me, I am going to try my own dual gage bezel and I want to add oil temp and I am not sure what else, maybe coolant temp also ...
If i get the tuning software this winter i'm planning on i'm going to probably cut the volts gauge and install a wideband O2 in it's place.
~Josh
Skip the volts and go straight to the wideband. Why spend money, if you know it's just coming out in the spring? That's just my opinion though!
Mark
If you need a volt gauge... and need a radar detector, the Escort 8500 x50 has a display mode where it'll show voltage when there are no alerts. You won't hog up a gauge port for voltage then.
