high speed vibration
bobdorit
Hi my car vibrates at speeds higher than 110Km/h
I balanced all four wheels two times! but still there is vibration,
I think probably the rims are bended, Although they are balanced!
Is it possible? I have 15" five spoke aluminium rims.
Or I think probably the hubs are out of run! Have any body heard anything about possibly bended hub?
I appreciate any suggestion.
thanks
Could be bad rims. You can still get a balance even if they are. If you can swap to another set that will be the tell tale. You could have a bad wheel bearing, a bad axle or even a tire with a slipped belt. Bushings in the control arms could be worn as well.
I have seen every front wheel drive car I own have eventual vibration problems at the rear when tires get out of round. They will still have PLENTY of tread, just jack up the rear on one side and spin the tire, you'll see it, as much as 3/4" sometimes. Tire brand cheap/expensive will move that quality around, you'll lose MORE cash on the expensive tires because they have more rubber/tread than cheaper and thusly will get more out of round. Vibration will get bad enough that you will change the tires before they are nearly worn out. I think it's because there is no weight on rears anymore like when had full rearends back there. The assembly then is able to move up and down in harmonics while at speed where old time rear weight loaded tires/wheels enough to damp most of that out. As a result, I don't buy tires in 4s anymore, only in pairs. New ones go on front and fronts go on back. All the back wheels do anymore anyway is force the front of car to track straight. You need all the control on fronts now, and the fronts don't start that pattern mentioned above until they go on the back, because of engine/tranny weight. Since doing that, I am now able to wear out backs all the way to cord/steel if wanted, by then the vibration will have started but now the tire is worn out, change it. I buy tires more common now because only 2 but individually I get much more wear out of them. The tire bill gets spread out more too, easier to pay it.
By the way, that vibration problem I mentioned is usually at 50+ mph, faster you go, worse it gets.
Might be cheaper to have a professional diagnose first though. Why do you think the wheels are bent? If they are factory wheels I'd doubt they are bent unless you can see it.
High speed vibration could also be due to bad struts and/or springs (front and/or rear wheels).
Struts were my issue when I had similar problems--vibration at high speed. Can be a safety issue since wheels are not making consistent contact with road.
