The other day really was the first time it was warm enough to test out the A/C, turned it on, heard the A/C compressor make its "click" noise, motor revved up about 250 rpms every 10 seconds, air didn't get cold.
so I tested a couple of things, checked if there was any leaks in the system by putting a pressure tester on the A/C line, A/C was perfectly pressurized, so I know its not because of low R134a. So I poped the hood, turned the A/C on and noticed something a little odd. Whenever the A/C compressor kicks on, I can hear a deep note coming from the air intake, it almost sounds like a half a second long "Moose"
I am also wondering, if the motor is revving up too much whenever the a/c turns on, which leads me to believe that the clutch inside of the compressor is done for, so when the A/C trys to come on the compressor never actually engages, yet the engine still trys to compensate for the extra power needed to run the A/C system, which would explain why the engine revs up a little bit every 10 seconds.
thoughts? Opinions?
thoughts? Opinions?
