MCconnection cc
I replaced my drivers side axel because the cv joint was bad. Everything went smooth with the exception of getting the ball joint back into the hub assembly. I ended up putting the ball joint on the hub assembly and then put the hub assembly on the strut tower. I tightened everything and now I get a rubbing sound from the drivers side whenever I go over uneven road, turn right, or vere right. No visible rub marks... Any suggestions would be greatly appreciated. I did search btw and I couldn't come up with anything...
