FavoriteMystaque
- Joined
 - Oct 16, 2004
- Messages
 - 1,192
IIRC the fans don't work w/o A/C either.  You would have to stay very near home to avoid overheating!
			incase it makes any difference this is what my fuse box looks like. All the fuses are good. I'm going to try and see if i can get a 12v signal in the small pin spot going to the relays.
	Yes..not really wanting to make a new thread, but how can i bypass everything, and make it so the fan always spins ...
is that the modenino ..... fix?
thanks
Yes, splice a wire into the black wire with the white line, and then ground the new wire. Make sure the ground is on metal and not paint.just so i make sure and do this right......lol
i splice into the black wire with the white line? and ground that to the frame/fender or something along those lines.
