rustyvolvo
New CEG'er
- Joined
- Feb 7, 2007
- Messages
- 14
I'm a little confused. I did a search through the forums to find out if the pre '98 hydraulic lifter heads could use the Focus Mechanical lifter Cams. The answer was yes and no depending on the post. In looking around Crane has only one listing for cams to cover all the contour years whereas Burton power breaks it up. Also the aftermarket larger valves are listed as the same part numbers for all zetecs. Usually you try to keep a mechanical cam with a mechanical lifter, so is this a matter of replacing the lifters on the silver top head with Focus ones?
I've got two silver top engines that I was thinking of starting to modify.
