rollinstylee
I was bored today so I went to the shop and did the shifter mod. For more info and searchability of this post, the thread size for the shift knob is M12x1.25 as I found in another thread. I ran the die down the existing threads and continued down the shaft a little over an inch, left the die on the shifter, cut 1" off the top (a couple new threads past the end of the original ones) with a vertical band saw, chamfered the new edge with a belt sander at about 45 degrees to allow the knob to screw down farther, and then backed the die out to clean the new threads. As an added touch, I shortened the reverse lockout by cutting out a 1" section from the middle as seen in the pic, again with the vertical band saw, and then 5-minute epoxying it back together. Works and feels like a dream, and it looks how it should have looked stock! No comments on my cheapo gauges, that was another "bored" activity and I like'em.
