hylix
Disclaimer:
I have been a member of these forums for a little while now, Searching, and leaching info. hence the noobie post count (more reading and searching than blabing). please go easy guys.
Is it at all possible to use 2.5L cams with 3L timing components?
Searching turned up this:
http://www.contour.org/ubbthreads/s...allposts&Main=1138125&Search=true#Post1138498
If pre 2000 duratecs use Wide chains / sprockets and post 2000 use Narrow chains / sprockets
I can only assume that if I have late '99 / 2000 SVT cams that they would work with a '00+ 3L
What I do have is a set of SVT cams from a '99 model year. I am assuming that they are the Narrow sprockets just by looking at them. I also have a 3L (from an '02 sable) being shipped to me and should arrive late next week.
What are the chances that the '02 3L I ordered will have timing components compatible with my cams (ig. late model 3L + late model svt cams = match?)?
Or is there some other difference making it absolutly necessary to swap the 2.5 timing stuff onto the 3.0?
the reason I ask is because I want to be able to pull my '00 SE motor and drop the 3L in with as little down time as possible. Meaning I do not want to rip all my existing 2.5 gear off and reinstall on the 3L. I do realize that means buying all new front covers and such, and lotsa extra $$. If I can use the existing 3L timing stuff, that saves me a buncha cash from having to buy duplicates. Also IF I can use my cams with the 3L gear, do I still need to install the 2.5 timing covers due to the different F.E.A.D. or can I make use of the 3L ones?
I have lotsa time to spend building this 3L, but I don't have much time to have a car with out a motor in it. and any dollar saved on trivial parts is a dollar spent on performance parts
Thanks in advance,
Rob
Thanks in advance,
Rob
