96Mystique
- Joined
 - Oct 18, 2007
- Messages
 - 192
I have a '96 Mystique with a 2.0L Zetec, with an auto trans. Just within the last few weeks, the car has been terrible. It's died while sitting at lights, and stop signs, even while driving slow. Only does this when the I don't keep my foot on the throttle, to keep the RPMs around 1k. Well, here lately, the car has started to jerk, while driving. Seems like it only happens in second gear, and gaining speed. Here's the twist. I was measuring my MPG, by resetting the trip-o-meter (whatever it's called), everytime I would fill my car up with fuel. I would divide the miles I have driven by the amount of fuel that was put in the tank. I was averaging about 25-27MPG. The last 2 times I have filled up the car, I've been averaging 30-33MPG. This is while the car has to be kept at around 1k RPM idle, and all the jerking. When it first started happening, I got a code, which was P0102. Mass Air Flow Circuit low input. It did this before, and I bought a new MAF sensor, and it curred the problem, or I thought it did. I then thought it could be the wiring, so I followed it as much as I could, and everything seems fine. I'm beginning to think it's just the transmission going out, but since I'm not a mechanic, nor any good with transmissions, I'm here asking for suggestions that you all think it may be?
Just if it matters, I can not tell if the car is in O/D or not, as no lights, nor the button works?
EDIT : There is a cold air intake on the car. Which may be the cause of the trouble code? I have been wanting a factory replacement, but have yet to find one. Even when the old air box was on it, it gave me the trouble code though.
