Hey guys I am sure this situation is going to baffle the living crap out of you all. I need serious help
Ok I got a no charging light on my alternator so I pulled it and replaced the alternator. Put the new alternator on the car and no charging light so I thought I was good. At this time I was getting a low coolant light, which is odd becuase i put new coolant in.
I have also installed a new water pump, thermostat, and new exhaust system.
Put the new alternator on and still not charging the battery becuase my meter is only showing 11.9 volts with the car running. When I disconnect the battery the car shuts off.
We pulled the alternator off (again). And yes we figured out how to remove the alternator without taking off the axle , exhuast, etc.. All u need to do is unbolt the wheel, sway bar end link, and tie rod end. We had the battery tested, and it tested good. Tested the alternator and it tested good. Brought it back to the house re-installed it and brought out the volt meter.
We check the mega fuse and its good (opened it up and looked), then check for voltage at the alternator on the wire coming from the batt. Both showed the same voltage so we have continuity there.
with the ignition on the green/black wire going to the dash from the alternator is showing the same voltage as the battery which is telling me that its getting power from the battery and sending that signal to the car. (explains not seeing a no charge light)
Once we start it up again no charging. I am at a complete loss at what to do!
My best guess is that the charging system is on the same circuit as whatever trips the low coolant light. However the haynes and chiltons manual circuit diagrams completely suck.
We checked the fuses and they are all good, none blown.
HELP!? and good luck figuring this out becuase we're lost now!
