moneypitsvt
New CEG'er
- Joined
- Aug 7, 2006
- Messages
- 21
I am in need of some SVT contour help. I have a 98 csvt with a myriad of issues. Most I can live with and can be fixed over time(air conditioning not working) as well as others. However this morning was a first. It has been starting a little rough(and clears up after about 5-10 seconds) and does this only when starting cold-not warmed up so( I just stayed up late last night checking the pump screen-it was fine) so I know it is not the screen...but it completely died on me in rush hour traffic on a major highway-then started again ran fine for a moment -cut out-then came back-then died and I had to have it towed. When upon arrival at home it started. I replicated the situation and it seems to happen when it gets to operating temp/I think? as it died in my developement after I drove it around. The IAB valve has just started to hang the idle at 1500 and falls ocassionally and I had to replace my TPS sensor as that went bad this week as well. I am going to clean my valve today but does this sound like a coil(by the way no cel at all-and it does turn over-I have checked my fuel pressure and it is fine-but when it dies-I go to start and no spark!.) Does the 98 SVT have a Ignition control module??and if so where? The parts houses list a part but after the TPS fiasco(had to go to Ford for the part) I really do not trust them so help-please!! I am so close to losing my head over the problems with this car. I am ok with stuff as long as it gets me to work-but it is of no use to me if it does not even do that. I just want it right_Mike
