harrup
Check Engine Light stays on so went to Autozone.
How do I know which catalytic converter to replace. When it went bad in my 95 you could hear it but no sound on the 2000.
Also, the code says the cat failure is caused by engine misfire or large vacumm leak or oil leakage into exhaust from valve guide seals or piston rings. Could the problem be one of these instead of the converter?
