WHEELSPIN
Can anyone point me in the right direction on how to remove trans to replace clutch. I did a search and had no luck. What the best way to do it, remove engine and trans or just trans? Thanks fellas!
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
exedy clutch
Nope.:help:
Why should anyone when there are perfectly good OEM clutches from Ford that work fine as it is? Anyone who does, usually regrets it unless they have no other choice like if they are going for bigger power from the engine. Even then, some regret having to do it.No good? or No one try it?
Can anyone point me in the right direction on how to remove trans to replace clutch..
