posthuman63t
I'm as ignorant as it gets when dealing with suspension. I never really looked into this area before (besides the last hour I spent searching for answers and advice). Basically, I am going to update my suspension since my drivers front spring is sagging (sits an inch lower than the passenger side).
I decided to go with the Bat Euro Kit, and want to update some other things as well. I have a couple questions.
1. I am going to be getting new Front sway bar links. The drivers side link is wore out, and the passengers side I'm sure is gonna be coming up soon. I have seen 2 versions, the "stock" version and the alloy version from bat. Is there any benefits to the alloy version? I read somewhere that Ford only sells the alloy version now.
2. My tires wear pretty even. I believe I read that if they are wearing properly now, they will most likely ride fine after, or it was the opposite of that. A little clarification please. So if the Camber/caster kit is required, does that take the place of the upper strut mount? (ie, I use the Camber/Caster kit or I use the upper strut mount). Regardless it will be brought to a shop to get a 4-wheel alignment.
3. I also noticed on Bat's site, a rotating bearing. Needless to say, what's this and should it be replaced.
Be kind (to a point, but heckle away), suspensions are not in my knowledge base. Thanks for your time.
