duboy
New CEG'er
I searched, but for some reason couldn't find what seems to be close to my issue.
I have a 98 SVT 125K miles, pretty much bone stock minus, susp and a tune. The tune has been on the car for...at least a year now.
I was driving on the highway when suddenly the tach drops to Zero, then up to 1K RPM, then to zero and 1K and zero and 1K, meanwhile the car is not responding to throttle input, then it dies, so i pull over. pop the hood to see what's up, nothing "out of the ordinary" no fluids leaking anywhere, no smoke. Try to crank it, it turns over but won't start. pull out the MAF sensor, plug back in, turn over, won't start. Get back into the car, sit and think about it for a minute, run back out and check all the wiring going to the engine etc. about 2 minutes later, try to start, and it fires right up, idles nice and smooth. i decide to pull it off the interstate.
I get on local roads, everything seems fine, no CEL or anything on, so i decide to drive it home, only 1 mile away. I pull up to a stoplight and it dies again. I do the same routine as before, and it starts right up again. drive it home no problems no check engine light.
I've read about the alternator bad - wouldn't be the alternator though in my case would it? The battery has enough juice to fire it up without a struggle.
Obviously it's nothing related to the timing chain/tensioner, i'm assuming it wouldn't run at all if anything was out of whack there
I'm ruling out the tune right now because well...it's been on there for at least a year with no issues.
Fuel pump? could it be? Anyway, i'm stumped? anything i should look at next? Oh it idles fine once it's started, not lumpy, no weird noises. just...fine.
