2slowtour
i was seaching the old forum didnt find much .. can anyone help me out im lookin for a detailed one...
cool thanks for takin the time to type that... yeah i know im going with the svt heads and cams UIM , LIM .. i was just tryin to find some info with pics of the different kinds of builds... thanks again
phil
Dang that looks purty!
Nice work and I can see during your porting you had plenty of stuffing in those holes. Hopefully people tape off everything like you did too. I recommend pulling the cams out too to insure both intake and exhaust valves remain closed during the operation.
are you useing the svt cams or 3L cams ... and whats the level of difficulty to port match those..?
A few flaws with that thinking.Just pray that the jbweld doesn't give up!
If your gonna go this route the least you can do properly is to get whatever you need welded so it won't end by your piston in the long run...![]()
Yes you will need a "chip" to tune for the larger injectors. (among other things)ok so are you saying if I do a straight swap using all the 3L stuff I will need a chip to control the injectors if I dont have an SVT????
