Lt_hailBob
I've been searching and I can't find the link for throttle body optimization. Can somebody point me in the right direction?
What I would be tempted to do.
Purchase a used 65mm throttle body. Remove throttle plate.
Remove throttle plate and shaft from an SVT throttle body.
Take SVT throttle body and shaft with the 65mm plate to a machine shop and ask them to bore out the SVT throttle body to accept the 65mm shaft and elongate the slot in the SVT shaft to accept the 65mm plate.
Compare the angles of approach to the 65mm throttle body and port the inlet to blend into the new bore.
Maybe a stupid idea. Perhaps one should start by making sure there is enough material in the SVT throttle body to accommodate this. Perhaps there would be room enough for 63mm and the 65mm plate could be trimmed.
