Zetec in a Buggy
New CEG'er
- Joined
- Mar 27, 2008
- Messages
- 8
Hello All, I'm installing a 98 Contour Zetec into my dune buggy and actually have it almost complete. It's completely installed and has been driven around the neighborhood, can't drive on the streets until I get my taillights and muffler installed and figure out the rich running issue. I am using everything stock exept the fuel system up to the stock rail, the intake and exhaust. It is a Fiber Glass Manx Type Buggy with VW suspension, and trans, and is street legal, but doesn't need to be inspected because it's registered as a '73 Buggy.
I have a couple of questions about the engine that I can't seem to find anywhere.
1. Can I get engine harness connectors to replace broken ones, such as the CPS and Temp Sender, others needed also, but aren't completely broken like the two listed.
2. Are there pictures, names and locations of engine components to help better identify if problems arrise? Such as the cylindrical component on the end of the fuel rail (has a vacuum line), the two sensors below the fuel rail what are they and what do they do?
3. I am using the computer, but don't care about CEL's unless they alter the engine management. Do I NEED the exhaust gas sensors for engine management or do they just turn on CEL's? I have been told different things here. I need to know for sure. What about a Vehicle Speed Sensor, does this alter engine management or is it mainly used for Odo, Speedo, and Cruise?
4. At this time it's running very rich and hesitates at high rpms when under load. Any early diagnostics on this from anyone is welcome. I still need to still install a fuel pressure regulator in the fuel system as soon as I find an inline Fuel Injected unit that will work. What is the fuel pressure needed for the 98 Contour? This might be my issue with the rich running because of the lack of correct fuel pressure. Is the stock FPR installed in the tank, which end is the input and exit?
This is all of my Q's for now, thanks to everyone in advance for your help.
Mark in Raleigh, NC
Mark in Raleigh, NC
