WHEELSPIN
I tried searching for info on the whole fact about not taking right turns to hard because of some oil problem. Can someone fill me in on this or point me in the right direction. Thanks homies
The rumor is that due to the design of the oil pan, a hard right turn will cause oil starvation and early failure of the bearings.
Any way to resolve the issue? Is that why newer engines came with baffled oil pans?
I don't think it's a rumor anymore, it's pretty much been proved. Also, you can install a baffled oil pan.
This would be a pan from a Taurus or Escape 3L right? Or no? Enlighten me.Also, you can install a baffled oil pan.
This would be a pan from a Taurus or Escape 3L right? Or no? Enlighten me.![]()
I guess it hasn't actually been proven, but it's definately past a rumor. Somewhere in between I guess?
From what I've heard, the Taurus pan doesn't jive with the Contour subframe, but the Escape pan will.
Being repeated a lot doesn't negate its rumor status, it just makes it a popular rumor.
