		devanmc
Guest
So im going pretty far with the N/A mods and i wanted to create my own self indulging thread for people to ignore. :laugh: So we can discuss other ideas, cheap one or project ones for later. Im trying to make the fastest contour zetec atx i can. Should be fun and pretty quick.
mods at sz should be:
short ram with heatsheild or CAI
70mm Pro-m maf
30lb injectors
ported out TB
freshly clean intake mani
weapon-r headers
2.25" weapon-r down pipe
2.25" exhaust
cam gears
massive speed systems cam gear bolts
new header hardware
vct delete
svt radiator
external trans cooler
svt front brakes, rear disc
BAT rear sway bar
stock or SVT front sway bar(looking for input)
newer rear sub frame
front and rear strut tower bars
svt suspension(for now, cuz im poor)
braided brake lines
Some kind of tune
self dialed in cam gears
UDP from ebay, its very small and very lite
MAF adapter for filter
3"intake pipe
PCV system changed to "open" with catch can, instead of the stock "closed"
svt fuel pump(i hope)
-some weight reduction
gauge pillar pod
water temp, volt, oil pressure, and trans temp gauges
custom(1 off to my knowledge) svt gauge cluster modded for the zetec
MSD ignition coil and wires
Motorcraft Copper spark plugs
[i think there is more but i cant remember right now]
70mm Pro-m maf
30lb injectors
ported out TB
weapon-r headers
2.25" exhaust
cam gears
new header hardware
vct delete
svt radiator
BAT rear sway bar
braided brake lines
Some kind of tune
3"intake pipe
gauge pillar pod
 needs to learn what N/A means! turbo and such will eventually come but im 17 im no where near the funds needed for a turbo and forged internals
 besides, behind the wheel the svt suspension will make it feel like a whole new car. My current stock set up has 130xxx on it and one of the front springs are now broken. huge amounts or body roll and such currently
