i may be wrong, but i very highly doubt there is such a wire..i am refering to the trace, or little lines on the circiut board itself, wich you would have to solder onto at a point where a component is soldered on the same trace. and in that case you can't just tap into it or you may blow the amp IC, you have to match the impedence values, both for the safty of the amp and for sound quality. and no i'm not talking about an external amp, unless your car is equip with a factory external amp, and if it is then you MIGHT repeat, MIGHT be able to just tap into a wire, but you really should match the impedence, impedence is basically resistance in AC circiuts btw. like i say i am not familiar with this exact setup, i am just speaking from a electronic point of veiw, mabey someone else on here has tried it with some success, i don't know, good luck, and be careful not to f it up!
i will do some searching on the net to see if i can find any schematic that i might could help you with...do you have a model number or anything on the stereo and amp?
