fred22
hello guys ive seen on the batinc.net site that they are selling an oil accumulator for our duratec v6, so what i wanted to know has anyone brought one of these or something simular and is it A) easy to fit and B)worth buying one? Any info appreciated thanks
heres the info from the site :
Accusump Oil Accumulator
There have been some cases of Duratec V6 engine bearings being
burned up due to lack of oil pressure during hard cornering. We
can not confirm that this problem will effect all engines, but
we can recommend the best prevention. The most
effective way to protect wet sump engines from lack of
oil pressure situations is to fit a Accusump oil
accumulator. The Accusump remotely stores a volume
of oil (in this case 1 quart) under pressure to supplement
the engines oil system during maneuvers that cause fluctuations
in oil pressure such as hard cornering, braking and acceleration.. If
the engines oil sump pick-up becomes uncovered the Accusump
will discharge (for up to 20 seconds) supplying oil pressure until the
oil supply to the pump is returned. Discharged oil is returned to the
Accusump when normal oil pressure resumes. An added benefit is the unit
also pre-oils the engine by supplying oil pressure before start-up. Accusump
mounts remotely in the engine bay and is electrically controlled with a solenoid valve wired to the
ignition switch.
This supplies oil through hose to the oil filter location to an adaptor mounted between the block and the filter. This
is the oil input to the engine on non oil cooler equipped cars (pictured). For oil cooler equipped cars (most SVT's)
we can supply components to run the oil supply directly to one of the engine block oil galleys.
ignition switch.
Accusump Kit $379.00
includes 1 quart cylinder (size12" x 3 1/4"), electric valve, hose- 6' length Aeroquip FC333, Aeroquip fittings
(1) straight (1) 90 degree, Mocal sandwich adaptor and fittings.
