starjammir
Well after I put the new TPS on my car after getting the trans in, the car seems to idle at 1100 RPMS (according to my window switch for nitrous). Also, the car seems to have some massive throttle hang going on when I drive it. So I took it in my garage and took the cap out and put one with a smaller hole in it. Reset the computer. Nothing changed. Put the old one back in, reset the computer. Pulled the IAC off, and put another one I had on laying around in. Started the car, and it idled at 1100 still. Gave it some gas and it hanged around 2500 then set back down to 1100 after 7 seconds. I pulled the connector off the IAC, and the car did not seem to hang at all. It revved fine. No hanging, but the idle was still at 1100. Any thoughts on this? Vac leak? Bad IAC's? I checked all the vac lines to make sure they were on, and sprayed some carb cleaner around. Nothing. Im so lost!
Since the winter, I added a opted mustang tb (with the stang/svt gasket), and I gasket matched the upper to the lower. Think the tune doesn't like these?
EDIT: Another thing, my wideband is showing that my idle is around 16.5. Dunno if that makes a diff or not.
