Soaking Grille
BlackE1
Genoa City WI
The grille has been soaking for 2 weeks now. I checked its progress today. How do I know when it’s done soaking? It is starting to peal / flake off but in some spots it seems like it is still attached.
Here are some pictures:
It depends on the brand of the grill and if any paint work was already done to it. Mine only took 1 week, but I did one for a local CEGer and it took 3 weeks.
Everything should fall off on it's own if you shake it around in the acid a little bit. If it doesn't, it needs more soaking.
It needs more soaking then. I will check it in another week.
On a side note how did everyone dispose of the acid when they were done?
Ask LUCA, she dumped it in her lawn and killed the grass! :laugh: Call your city/town/whatever and ask if they have a special place to dump it. You may have to wait for one of those hazardous waste days.
I used this stuff to help bring down the PH in the swimming pool my parents had. I think if I dilute it with a ton of water it should be ok to pour out somewhere where there’s nothing it can harm.
I only killed the grass where some of the acid dripped out. LOL! I did dump it elsewhere after I poured a load of baking soda into the container.
It's cold where you are (BlackE1) so it will probably take upwards of two more weeks for all the chrome to come off. I noticed when I did a few in the winter that it took longer than it did in the summer.
When it's done, make sure to pour some baking soda on the trim ring, I let it sit covered in the baking soda for a few minutes to neutralize the acid and rinse it thoroughly.
just sand and paint it , i did mine like three years ago and its holding up great, took me like 15 mins to sand it,F that 3 weeks crap :crazy:
I thought about it but I am one of those people who like to do things right the first time no mater how much money or time it takes. I bought a second grille so having it sitting for 3 weeks doesn’t bother me since my car still has a grille on it.
to get rid of the acid you might just want to get something to bring the ph of it back to a normal level and then dump it.
Yep, when it's cold it takes longer.
Good to hear that you've got it almost all done. :cool:
Baking soda FTW! ;)
Hey everyone!
I'm getting ready to go through this with my grille and I want to make sure I'm about to start drilling through the proper spots to separate the mesh from the oval. I have circled the areas I believe I need to drill out. Yes you are looking at two different grilles, top original and the bottom (runs and puts flamesuit on) is from ebay. I will be attempting this with the ebay grille first, if all goes well, the original...
I didn't bother drilling when i did mine, instead i used a chisel and cut away the melted plastic holding the mesh on. If you get enough of that overlay off the ring piece should just slide right off. Otherwise, just use a drill to drill off some of the excess "stubborn" plastic.
