I've had CELs on and off for about 6 months now. The dreaded p0171 and p0174 codes individually and together. Driveability slowely got worse and worse so I finally did all the intake and injector gaskets 2 months ago. It was easy to see where the upper intake gasket had failed. I also changed the O2 sensors to be safe. The result was better driveability but still the odd code (171/174). The other thing is that the car is a little low on power below 4000 rpm, and really low on power above 4000. In 3rd gear it will not pull above 5000 rpm ( yes the secondaries are openning). If I baby the car it may not throw a code for a week or more. If I drive hard I get the lean codes almost immediately, and the odd missfire code (changed plugs too). This led me to suspect fuel pressure. The fuel presssure is always the same, vacuum or no. It's 27psi and dropping when I rev the engine.
Correct me if I'm wrong but if the regulator was good and the pump was putting out a lower pressure, it should still increase when I remove the vacuum from the regulator? If the regulator is bad, fuel pressure will not change, no matter what the pump is putting out, right?
Sucks that here in Canada the best price I can find for a regulator is $75. Hate to see the pump price. BTW, the car has 225k kms on it.
