Matt2kSVT
Like it says, yesterday went to start my 2000 SVT and it stumbled a couple of times and died.
From all the posts I've read, that sounds like a flooded engine, which I've had happen once a couple of months ago. So I cranked it with my foot to the floor for 30+ seconds, no luck. I do hear the fuel pump whir a little bit when I turn the key to On.
Then I read all the posts about washed out cylinders, so I took out the 3 front plugs (they did smell like gas but were not wet) and put a teaspoon of oil down each cylinder, no luck. I also cleaned out the IAC valve while doing the teaspoon of oil.
I don't know what else to do, I'm about to call a tow truck. Anything else I should check?
