as stated on FCO if there was exsessive back pressure from the exhuast it would blow off the DPFE hoses first .... the egr valves hardly ever fail ....
That's not necessary since I'm going off of the reading right from the O2. I only swapped the O2's to make sure it wasn't the O2 itself misreading. If the O2 was the problem, the bank reading lean would have followed the O2 under these conditions.
I've never seen an EGR valve flat out fail, but I have seen them get stuck open from deposits.
Sorry, but adding ANYTHING at this point is throwing a part at it because I still do not know the root cause. Okay, the injectors are too small, but how will that cause only one bank to go lean at high RPM? I cannot theorize a how to answer that question, given the troubleshooting I've already done, so I pose it to anyone reading. Until a possible theoretical "how" is established, it's not a possiblity. Inadequate injector size is not a possible root cause of this particular issue.well that in itself could be the problem, injectors and tune, so if the problem is eliminated that you have your root cause since you have proved everything else out. the members of FCO are not suggesting that you just throw parts at your problem
I explore valid possible root causes of this issue. When anyone, even the "people that have experience" are blaming an impossible root cause, even after numerous attempts at trying to explain why it's not possible to be the root cause, it DOES tend to discourage me from listening to them continue to argue the impossible.What I see going on is that you are way to stuborn and don't want to take advice of people that have experience with these cars and engine, you want to hear what you want to hear...if you continue to ask questions and not follow any of the suggestions that you have received your going to stop getting any help in the future
I posed the question of how a vacuum leak could possibly cause this particular issue because I couldn't rap my head around it.
which makes me, and only me, an ass? :shrug:
When someone who should know what they're talking about offers a possible solution that doesn't seem theoretically possible in my mind, I ask how it is possible in hopes of learning something I didn't know. Doesn't that make sense?
I thought it was for saying that the Earth wasn't the center of the universe but either way, they DID put his ass in jail... crazy to think about. I realize you were not comparing him to me, but I can relate to being misunderstood and ridiculed. Allthough, it's almost good to know where to find a monkey that will just start thowingWasn't Galileo imprisoned for awhile for his theory that the world wasn't flat?
No doubt. There are definitely still things for me to check/eliminate/swap. The intellectual part of me just won't let me move on until I find the root cause. I'm glad I'm that way though... otherwise I'd just be anotherSeriously, you're at the point where you need to narrow down where the problem is coming from, even if you don't understand it exactly yet. If you narrow the scope of the problem further, by swapping some parts around, it will help you understand what is going on better and perhaps get through your current impass of understanding.
Yes, valves & springs are good.Are all the valves and their springs good?
That's why the EGR theory made so much sense to me. I'm still exploring the possible issue of an over-rich condition, AND the possibility of the O2 just reading that way because of the more-restrictive exhaust path for bank one. Back pressure test and exhaust-less datalog are next.your problem seems to be not a lean condition but a rich condition.
Definitely a good idea. Parts swap of PCM and possibly wiring harness are after my exhaust checks.you might swap a pcm... to see if it is possibly the computer malfunctioning.
That's why the other techs here couldn't believe that I was driving a Contour of my own free will. There were chaffing issues and even some wire insulation issues. The vast majority of them included a CEL, but I'm still going to check the wiring very closely.next i believe some of the older tours had wiring harness issues.
Yeah, I did that when I swapped banks.next pull all your injectors inspect them carefully
Yep. I made an air inlet tube and removed & cleaned the MAF before making use of the new tube. To answer the next question, yes the stock MAF is in the stock MAF housing.have you cleaned the MAF?
