zorrex
Enjoys the Abuse
Wires would be $50-80. Coil, not sure.
Bosch are $45 IIRC. I think those will suffice, although I've heard positives about the Duralast that I put in :shrug:
Don't worry the valve cover gasket is easy. I'll pick up a gasket and we can switch that out very easily. It is literally a 15 minute job. The coil pack is a little bit more expensive but I figure it might be necessary as it could be dying...
Zorrex, did you try swapping out your coil and wires over just to see how it runs? Or was there a difference between the years?
I'm just afraid the engine isn't doing too well internally. The last set of spark plugs were soaked in oil and misfiring...
it was misfiring because you didnt put the fourth cylinder wire on all the wayy DUHHH..the misfire was fixed after i pushed the wire in.
I pushed it on all the way, it just doesn't like me :laugh:
Linds if you want to come buy I can look at the car again and try swapping a few parts with my car if you like
