28 DAYS OF REHAB, looking clean
97GLblack
Minnesota N-burbs
today I have been a member for 28 days and I would like to let everyone in on the progress (rehab) of my car since aquiring a few days after signing up for CEG.
The beginning:
I had aquired a '97 black 'tour GL 132k Zetec/MTX
Cars dash was mutilated, all wiring for HVAC/ radio/ panel dim had been shredded/ rewired as well as wires going to the trunk and the dash/trim itself trimmed away.
This was all done as an attempt for an in-car computer from the last owner. along with this a 10 foot power extension cord (like the one you use for your power tools) was run to the trunk from behind the dash, other misc. wires run to the trunk.
Trash in trunk/ glove box
center console once removed and damaged (holes, covered in ashes, missing: armrest clip,cupholder bezel/cig lighter/ashtray portion) then only part way installed. E-brake boot torn. moonroof problems.
Most importantly there was some type of engine/electrical problem that was not solved by an alternator swap. :shrug:
no heat from engine
back bumper fitted with wall-drug/ phone-geek stickers.
driver's door handle molding missing
driver's sun visor destroyed (keyboard install)
driver's side mirror damaged
a pillar trim missing
glovebox backing cut out
trunk vent broken, water(ice) in trunk
lug wrench missing
NOW FOR THE UPDATE:
I had removed the badging and bumper stickers
repaired the entire center console, e-brake boot and replaced all missing parts, upgraded cupholder
repaired all wiring/ Radio/dimmer/hvac wiring and reinstalled hvac controls
fixed alternator/ new battery/ inspected engine wiring harness visually by recall standard/ tested megafuse/all fuses
changed thermostat
I have located majority of missing parts
upgrades:
Added tach
debadged
billet grill
cougar cupholder
lighted moonroof switch
In progress:
stock foglight install
cougarS pedal/dead pedal install
autodim mirror
Future upgrades:
accent rings in foglights to work w/blinkers
mystique door panels w/ power windows
change seats from knob to lever or upgrade to power seats
rewire taillamp to except newer style bulbs (pre98-post98 conversion)
heated mirror recontent
flush mount gas cap recontent
PICS:
Parts needed:
moonroof gears and gearcover
heated side mirrors
clutch and brake pads from cougarS
mystique door panels w/ power locks/ window motors
and wiring to add power windows
stock CD player
I want to thank CEG members for the help and information as well as JoeM for the parts.
When it is all done I will be inviting local CEGer's to come by and hang out/ test drive the new car so stay posted in the North Central forums.
there's a black pre98 at my local yard its a 96 se and has the heated mirrors. and grey interior.
Throw some D's on it! I keed!
BTW I have a gas cap from my 96. It's black and would work out well for your recontent.
Did your car originally come with power windows or are you wanting to add them on?
I use to have the wiring for power windows when I wanted to upgrade it to my old Contour, but then I got rid of the car and later on threw the parts away.
I have 2 side mirrors heated if you want to buy for a really good price. Pm me for details
update: been kinda busy but still finished cleaning up the trunk got the grill installed and resecured the new boot that had come loose. still need to fix the side mirror, change the oil and fix the moonroof.
