CEL on with 3 codes!
FauxhawkFox
I plugged my OBD II scanner in and there were three codes posted. I know that one of them is the O2 sensor (P0153)
Heres where I need help.
P0340- Camshaft Position Sensor circuit fault. Where would I look? How do I fix this? Am I FUBAR?
P1151- scanner says "Manufacturer Control Fuel/Air Metering"
O2 sensor as well? I got a full list of codes from CEG and it says it is bank 2 as well.
For P0340, Unplug connector, unscrew bolt, remove sensor. Reverse steps for installation.
Read post No. 7.
http://www.contour.org/ceg-vb/showthread.php?t=19158&highlight=camshaft
For P0153 and P1151, time for a new Bank 2 (radiator side) Upper O2 sensor. This is the sensor to the left of the exhaust manifold when you are looking from the front of the car. Remove the oil filter for better access (and space to turn the ratchet). You need a 22 mm (or 7/8 inch) open ended or crescent wrench (about $8). The O2 sensor removal tool costs $12 at Advance or Autozone.
